First post, by JKing
Has anyone tested this game in DOSBox 0.7 to confirm it still works? After some success and, moreover, acceptable performance with Privateer and Strike Commander, I thought I'd finally give Wings of Glory a try, but it crashes on me with "error #fffd" after the "ORIGIN" screen. I have EMS turned off as suggested in the game database, though whether it's on or off seems to make no difference in this case.
Reply 1 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Is the sound set correctly?
1+1=10
Reply 2 of 5, by JKing
Yes. Also, the first thing I tried was to run it without sound; the result was the same.
Reply 3 of 5, by Mirir
Yes, it still works. You must put core=normal and ems=false.
"Every one sees what you seem, but few know what you are" Niccolò Machiavelli
Reply 4 of 5, by JKing
Ah! I hadn't expected the dynamic core to be the culprit; thanks! 😀
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
Interesting, thanks for telling.
