First post, by DosFreak
http://www.japheth.de/
HX DOS-Extender is a free DOS extender with built-in Win32 PE file format support. Usually the purpose of a DOS extender is to make protected-mode features available for DOS applications. HX fully supports this goal, but goes some steps further. A Win32 API emulation layer is part of HX which allows many Win32 console applications to run in DOS. This emulation goes far beyond similiar approaches in other extenders (Borland's PowerPack, WDOSX or Phar Lab TNT). Furthermore HX implements - limited - support for windows, DirectDraw, GDI and even OpenGL graphics. This allows to run "simple" Win32 GUI apps in DOS as well.
There isn't a unified changelog but if you check the DOCS subdir in the .zip's and scroll to the bottom you can see the numerous changes.
Make your games work offline
Reply 1 of 4, by eL_PuSHeR
Interesting. Thanks. 😎
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 4, by Zorbid
Among these "simple" Win32 GUI Apps lies... DOSBox 😀
Has recursive emulation ever been achieved with DOSBox?
Reply 3 of 4, by DosFreak
Bored? Try running Qemu inside of DosBox using HX Dos Extender and HXGui
mirekluza DOSBox Moderator no avatar Joined: 2003-08-21 Posts: 1754 I have always had the wish to be able to run DOSBOX inside […]
mirekluza
DOSBox Moderator
no avatar
I have always had the wish to be able to run DOSBOX inside DOSBOX. Yes, it would be useless, but it would be a nice achievement.
It is now possible with the HX DOS extender.
1. I started DOSBOX 0.65
2 Then I installed the HX DOS extender (both runtime and GUI packages)
3. I started hxldr32 program inside DOSBOX
4. Then I started DOSBOX 0.65 inside DOSBOX (I just needed to add two DLLs to it MSVCRT.DLL and CRTDLL.DLL (SDL provided with 0.65 needs them).
5. DOSBOX worked inside DOSBOX
Ok, it was slow, but it worked. I tried a few commands in shell. Vey nice, though completely useless thing. Happy
Reply 4 of 4, by MiniMax
Rank Moderator
Moderator
Now all we need is a C++ compiler suite that runs in DOSBox, and DOSBox can bootstrap itself.
_________________
