Crusader : No Remorse
First post, by chainsoar
Now I know this problem has been posted before, because I did a search as all good forum users should before posting a question. However, and no offense to the people who tried to answer those posts, they were no help to me. Here's my problem - I've mounted my cdrom in DOSBox, I've started the setup program, and then when I start to go through the installation options it suddenly halts me with "Not enough disk space on this drive" or words to that effect.
I've checked the DOSBox readme and I can't find anything there to help me either. What do I do?
Thanks.
Reply 1 of 13, by dougdahl
Two options-
1-The game, as you have chosen to install it, needs more than 180 Megs. To figure out how to fix that, read the README, paying attention to freesize under the mount options.
2-Did you mount a second drive for the game to be installed onto?
Reply 2 of 13, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
sounds a lot like 2-
Chainsoar, please repeat your steps here, meaning please write us what you write and execute in Dosbox.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
I think it's number 1
Place your bets! 😉
Water flows down the stream
Reply 4 of 13, by MiniMax
Rank Moderator
Moderator
Option 3) He didn't read my excellent 60-seconds guide.
_________________
Reply 5 of 13, by chainsoar
What I did exactly, from the moment I opened DOSBox, was this -
mount D D:\ -t cdrom
D:\
install
Then when I click the option "Full install (55 megs)", to install at the destination C:\Crusader, it stops me with "not enough space on this drive". I've got more than enough space to accomodate 55 megs. What did I do wrong?
Reply 6 of 13, by DosFreak
DosBox only shows 110m of free space for mounted C:\ partitions when you do a
"Mount c c:\games"
you need to add -freesize XXX after it
EX:
"Mount c c:\games -freesize 500"
Make your games work offline
Reply 7 of 13, by Dominus
DOSBox Moderator
What I did exactly, from the moment I opened DOSBox, was this - […]
D:\
install
You don't have a folder on your hard drive mounted as C:\ as far as I see. You have to do what Dosfreak tells you. After installing, the next time you start Dosbox, you don't need to add the freesize parameter, Crusader works fine without it.
Reply 8 of 13, by chainsoar
Sorry, I still don't get it. I know how to mount my games folder, I'm having trouble installing the game from the CD. Am I being dense?
Reply 9 of 13, by wd
Rank DOSBox Author
DOSBox Author
Now please tell exactly how you're mounting. Should look like
mount c c:\oldgames
mount d d:\ -t cdrom
Reply 10 of 13, by DosFreak
In all of your previous posts you only mentioned mounting your cdrom, not your games folder.
In this comment you stated:
DosBox only shows 110meg free on any mounted folder for compatibility for older games that do not expect to see gigabytes of free disk space. To override this you have to specify the "-freesize XXX" switch in your mount command when you mount your games folder.
Reply 11 of 13, by Dominus
DOSBox Moderator
just checked the installation. Crusader does NOT need the freesize parameter, BUT it shows the "not enough space" when there is nothing mounted as C:\.
So you better make use of that knowledge:
@Qbix: I win 😀
Reply 12 of 13, by wd
Rank DOSBox Author
DOSBox Author
No you didn't, it was 3) 😀
