First post, by abyss
Tomb raider 1 runs a bit slow. I have 16 mb,dynamic mode,6000 cycles,10 frameskip set up. I am using dosbox 0.70. It is very playable but it is still a bit slow. I can only go up to 7500 cycles. Is their a way to run the game at full speed. I have to use low detail.
Reply 2 of 5, by gulikoza
Of course there is a way to run full speed - buy a better computer. I can run Tomb Rider at over 200.000 cycles.
http://www.si-gamer.net/gulikoza
Reply 3 of 5, by abyss
If i run it without dosbox i cannot get sound. It runs at a playable speed with the lowest detail with dosbox but it's a bit slow. How do i run it with sound and full speed.
Reply 4 of 5, by tannerstevo
Use vdmsound?
Reply 5 of 5, by leileilol
Get a processor higher than 500mhz?
