First post, by remoray
I cannot run populous I on either 0.63 or 0.70
On 0.63 dosbox dissapears
On 0.70 dosbox does nothing
remoray
remoray
I downloaded an abandonware copy and works just fine using DOSBox 0.70
Remember to run the game with command line parameters.
E.G.
populous.exe VGA Adlib Sound
populous.exe VGA Internal Sound
populous.exe VGA Tandy Sound
populous.exe VGA Roland MT-32
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
I tried all of those examples with no change. Doxbox just does nothing. I cannot even type on the command line.
Wouldn't running populous.exe without command line parameters have some result anyway?
remoray
Is the DOSBox Z:\> prompt being displayed at all?
If not try changing output=xxxx in the dosbox.conf file.
Intel i7 5960X
8 GB DDR4 (2100)
My mistake. My directory strucutre was wrong.
I now have Populous I running fine on 0.70
remoray
Glad to hear you sorted out your problem. 😎
Intel i7 5960X
8 GB DDR4 (2100)
