First post, by DosFreak
I set svgachipset=et4000
Installed the ET4000 '95 drivers included with Win95
Set res to 640x480 256 colors.
16bit/24bit doesn't work.
Previously I was only ever able to get 16 colors to work in win95.
    7.88 KiB
Make your games work offline
Reply 1 of 1, by DosFreak
Installing DX3 (which installs a DX certified Tseng driver) seems to make Win95 unstable.
800x600 works fine.
Also I just loaded up the command prompt and it didn't totally corrupt the screen like it usually does but it did distort it.
Changing the screen res while the command prompt is loaded "fixes" the issue.
    6.52 KiB
    150 downloads
