First post, by svartberg
Thanks to dosbox I can play this classic again.
Unfortunately I miss the original new horizons music I used to play with - I can't get it to use general midi, nor can I run instmain.exe to setup it. (it just doesn't respond)
If anyone knows of any way or walkaround to get uncharted waters 2 to use a better sound system (like general midi) it would be appreciated.
Reply 1 of 2, by VisitntX
Try to run the setup with the core set to normal.
Reply 2 of 2, by svartberg
That didn't help, however when I ran grpdrv.exe and then[/i] the instmain.exe it worked.
Unfortunately, instmain.exe doesn't let me setup the sound - so no idea how to get the general midi working in dosbox 🙁
