First post, by dbarton
- Member
If i run my app with MIDI drivers, I get MIDI.
If i run with soundblaster drivers, I dont get MIDI.
Is this normal?
Is this normal?
I don't know, but don't forget that the first soundblaster card to TRULY support midi was the sb16. the sbpro and sb 2.0 had gameports which had the midi functionality, but afaik they could only be used as midi INPUTS, as they were not mpu401 compatible. the sb16 was.
Lord Nightmare
"When life gives you zombies... *CHA-CHIK* ...you make zombie-ade!"
