First post, by pepoluan
I tried installing DOSbox 0.70 on my laptop and my workstation. I got the Windows "Application Error" stating:
The instruction at "0x6812e699" referenced memory at "0x00000104". The memory could not be "read".
What gives?
    5.39 KiB
    Screencap of Error Dialog Box (6KiB PNG)
I use ISO-8601. You should, too!
Reply 1 of 11, by DosFreak
What operating system?
What video card?
What DX version?
What video card driver version are you using?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 11, by Kreshna Aryaguna Nurzaman
And does it happen on both your laptop and workstation, with exactly the same error?
Kreshna Aryaguna Nurzaman.
Reply 3 of 11, by pepoluan
Workstation is Windows 2003, laptop is Windows XP.
DirectX 9.0c of Feb 2007 is installed.
I use the standard drivers given by Windows.
I'm not sure if the error address and reference is exactly the same. I'll check 'em first.
{p}
Reply 5 of 11, by pepoluan
Gee, I thought I have posted my reply... 😦 ... apparently my ISP had eaten my reply. So, here's an update:
For the Windows 2003, I have installed 865 driver from Intel. Now DOSbox runs without error.
No such luck (drivers) with the laptop...
Reply 7 of 11, by DosFreak
What kind of video card in the laptop?
Reply 8 of 11, by pepoluan
Now that's the problem... I have no idea. It's not really my laptop, just one 'entrusted' to me by my office.
Reply 9 of 11, by eL_PuSHeR
Rank Moderator
Moderator
Well, you could try running a system identifier software such as Everest or SiSoft Sandra to find out.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 10 of 11, by Peri
I have the same problem, the weird thing is that DOSBox 0.65 works fine. The problem only occurs with DOSBox 0.70. but I tried the 0.70 version in my other Windows instance (clean installation) and it works good. I don't know what is the problem. :<
Reply 11 of 11, by butterfly
That's been suggested already but when I tried DOSBox on Windows 2003 I experienced the same problem. It was enough turning hardware acceleration to the max.
