First post, by stiffla
hello to you all
i am really new to all this and dropped on an old classic game i like which is fade to black... which doesnt work as it requires dos ?? well i have downloaded dosbox followed instructions and i still cant get the game to play
the game is located in ,my cdrom drive, i have mounted the drive using the command as shown on the help page
mount d d:\ -t cdrom which worked fine i then prompted d: install which initialised the installation screen for the game i selected english of corse and then it takes me to the minimal / medium / maximum install which you select for better gameplay etc.. i have tried all three but when i have selected the next screen is where i want to install to which automatically has c:F2b i then click ok this does not work not enough memory ??? i am now really stuck as i say i am really new to this the memory of my pc is fine why wont it let me just install and run the game where can i go from here .....
regards
stiffla
Reply 1 of 8, by stiffla
sorry to admin please move my thread i didnt see the do not post about dosbox here .... sorry
Reply 2 of 8, by eL_PuSHeR
[Moved]
[Rewritten thread's title a bit]
Hello, stiffla.
Please post here all exacts commands you used for mounting all drives under DOSBox as well as any error messages you are getting for the game.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 8, by DosFreak
It sounds like you mounted your virtual cdrom but not your virtual hard drive.
You need to specify a "C:" drive in DosBox so that your game can install.
Ex: "Mount c c:\DOSGAMES"
Assuming that you have a "DOSGAMES" directory off of your C:\.
Make your games work offline
Reply 4 of 8, by stiffla
DosFreak wrote:
It sounds like you mounted your virtual cdrom but not your virtual hard drive. […]
any chance you can talk me through it on how to set it up please
Reply 5 of 8, by eL_PuSHeR
Create a folder named OLDGAMES on your C drive from Windows Explorer.
After that, start up DOSBox.
Z:\>mount c c:\oldgames
Z:\>mount d d:\ -t cdrom {assuming second d letter is your real cd letter. If not, replace it}
Z:\>d:
D:\>install.exe (or setup.exe or install.bat or whatever. Issue a dir command to find out.)
{when prompted for installation destination, choose drive C. Installation will probably create a folder F2B in it}
{After installation is finished. It will probably redirect you to...}
C:\F2B\>
If not...
D:\>c:
C:\>cd f2b
C:\F2B\>f2b
That's it.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 8, by stiffla
right
i have created a folder on my pc in the dosbox folder on the harddrive named it dosgames i have then opened dosbox and typed in mount c c:\dosgames to which comes up directory c c:\dosgames does not exist any offers ???
Reply 7 of 8, by stiffla
followed your instructions many thanks it worked !!!!! 🤣
Reply 8 of 8, by eL_PuSHeR
Glad to hear it worked for you.
Intel i7 5960X
8 GB DDR4 (2100)
