640k free mem
First post, by Dreadnought
Hello to all 😀
Im using dosbox for running some old university softwares, some of them forks flawlessy, but one requires "more memory"
I think that i need to free more conventional memory, but dosbox give me a maximum of 634KB free 😒
Is there a way to have more conventional memory (aka the full 640k free)?
Tnks in advance 😊
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
You'll never get the "640k free" because the interrupt table has to be
somewhere. Most programs that output a message about not enough
low memory have some underflow. Try loadfix before starting the prog.
Reply 2 of 4, by Dreadnought
the program is slightly old: 1991, it was written by a student, probably a programming-noob, i thought about some other error masked by an "insufficient memory", but the program doesn't have any readme/parameter/config...
Tried loadfix but didn't work...
Reply 3 of 4, by DosFreak
Try loadfix with higher values. By default IIRC it only eats up 64kb.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
