First post, by spaceagedevice
this was very frustrating process but guaranteed to work. First of all, if you have a Mac Intel, you will need Boot Camp/Parallels(preferred)I found a DVD installer on the web called Pandora Directive Installer 1.1 HERE which I used to make 1 DVD for all 6 Cd's. So next after you make a DVD of the folder the DVD installer made, I used Toast, head to DosBox.
mount c /Applications (or wherever you want to put Pandora dir)
mount d /Volumes/pandora1 -t cdrom -usecd 0 -label PANDORA1
goto d:, install
then after install (you should be in c:\pandora) type Pandora
Hope this helps!!
Reply 1 of 1, by wd
Rank DOSBox Author
DOSBox Author
Thanks for the information, if the label parameter is really needed it
might get tricky when changing cdroms. CD images might help then.
