First post, by kennyrh
Don't know if anyone has encountered this problem. In XP using dosbox 70, it sets up okay but when I go back into dos to start the game it comes up with a message that says it can't open the game.dat.
Can anybody advise . . .??
Reply 1 of 21, by MiniMax
Rank Moderator
Moderator
What does that mean?
_________________
Reply 2 of 21, by eL_PuSHeR
The error is stated in the thread's title, namely: can't open game.dat
Are you mounting everything correctly? Please write down all mounting commands used.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 21, by kennyrh
Okay . . .here's the full details.
I can install from my CD drive within dosbox and I can set the game up from my games folder in c: drive so I assume everything is mounted okay within dosbox.
After setup of sound card etc, I quit out of setup and go back to dos command line within dosbox. I type in "sr" to start the game and the "can't open game dat" error comes up.
Exactly the same thing happens with Screamer 2 and I remember that these games were a bitch to get going even on my ancient PC of 7 years ago . . . 😕
Reply 4 of 21, by MiniMax
Rank Moderator
Moderator
Let us try one more time:
_________________
Reply 5 of 21, by kennyrh
Sorry to sound a bit thick . . .but I'm not sure i understand the question.
Do you mean what commands did I use to mount my games folder and cd drive in dosbox . . .??
Reply 6 of 21, by Qbix
Rank DOSBox Author
DOSBox Author
I think he is asking for what you have typed inside dosbox.
from the start till the point the game crashed back with that error.
Water flows down the stream
Reply 7 of 21, by eL_PuSHeR
Exactly.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 8 of 21, by kennyrh
Okay . . .I used this tip from another forum which said to add this to my config file in dosbox
loadfix -64
mount e e:\ -t cdrom
mount c c:\Games
So within dosbox all I have to do is type c: to access my games folder or e: to access my cd drive.
So with Screamer Rally, i went into dosbox and typed e: to access the cd drive.
I then installed the game to my c:\games folder
I changed to c: drive in dosbox and setup the soundcard etc.
I quit out of setup with "esc" and got returned to my c: drive in dosbox
I type in sr.exe to start the game and then the error occurs . . .as if it can't find my game.dat file.
Hope that explains everything . . .
Reply 9 of 21, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
is your game.dat file in the directory you installed SR to?
And just maybe it doesn'T like the CD-Rom at e:\, so try to mount it to d (e.g. "mount d e:\ -t cdrom")
It's probably not affecting it, but just to make sure.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 10 of 21, by eL_PuSHeR
Dominus is right.
For mounting the CD-ROM drive, first letter is the letter you want under ODSBox while second letter is the drive letter corresponding to the real CD/DVD drive.
For instance, most ms-dos games will just require a hard-disk drive (C drive) and a CD-ROM drive (could be D drive).
My real DVD-ROM drive is H: so, we would change that mounting line to:
mount d h:\ -t cdrom
As for the hard-drive mounting line, folder GAMES must exist (be created) at the root of your real c: drive. If not, it will give you an error when trying to mount it.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 11 of 21, by kennyrh
Mmmmmm . . .tried mounting d as my e:drive (CD) but no luck . . .
. . .then i thought i would change my dosbox config to mount c: as just the root drive and install screamer rally into the root of c:
Now it gets past the game.dat error but tries to start and then says there's no screamer rally cd in the drive 😕
My cd drive mount is def okay because i installed the game in dosbox from it.
So i seem to have solved one problem just to encounter another.
Tried a couple of no cd cracks but they didn't work either.
If anybody has any other suggestions . . .I'm listening . . . 😠
Reply 12 of 21, by MiniMax
Rank Moderator
Moderator
I would remove the various files and directories you have created so far. Then create a new fresh C:\GAMES directory, redo the mounting and installation of the game inside DOSBox.
_________________
Reply 13 of 21, by dh4rm4
also try the -ioctl switch for mounting the CD
Reply 14 of 21, by kennyrh
Yes that did the trick . . .hooray !!!!
I found a post by somebody else with the same problem and they suggested to try this . . .
. . .anyway thanks for posting it and thanks to everybody else who tried to help.
I guess persistence pays in the end . . . 🤣
Reply 15 of 21, by IIGS_User
So the problem occurs, 'cause you installed the game *outside* DOSBox?
Klimawandel.
Reply 16 of 21, by Dominus
DOSBox Moderator
Just for documentation's sake, which of the proposed ways did help? The next person with this problem might benefit from your newfound knowledge 😀
Reply 17 of 21, by kennyrh
Well the original problem "can't open game.dat" was solved by installing the game in the root of drive c:
The can't find cd problem was solved by adding the -ioctl switch to the mounting info in dosbox config.
Both Screamer Rally and Screamer 2 I can run now by doing this . . .
Reply 18 of 21, by PlayDaman
I'd like to unearth this one, I'm having the same issue.
I am mostly a newbie when it comes to DOSBox, I tried my best to follow the instructions above and probably failed, seeing that the game doesn't work.
mount c c:/sr (latter is the installation folder)
mount d f:/ -ioctl (latter is the CD drive)
Setup works but the game still can't find the game.dat file 🙁
Reply 19 of 21, by Dominus
DOSBox Moderator
Follow the 60 seconds guide in the guide sections and use the ioctl switch for mounting the cd. And then install the game from within dosbox
