Maybe something's changed in DOSBox's code, i can't say that (there were many changes, probably). All i can say is that i've completed the main game and the addon with 0.70 and the settings i've described, and have had very little problems doing so.
It's your choice to either try the game with the settings i've described, or continue complaining about what you think is decreased stability. Your statement is in no way a proof that 0.70 is less stable than 0.65, after all - it's just your personal conclusion. If you think that 0.65 is "better" than 0.70, just continue using that version.
You have posted in an area of this forum where users normally ask for help about getting a specific game running. Maybe you should've posted in the devs section, with a detailed error report, your dosbox.conf, system specs, etc.. That would make much more sense than just saying the things i wrote are "unnecessary".
