First post, by Sinooko
I'm playing M.A.X. and the intro was skipping a bit and teh sound was kinda overlapping itself anybody have any tips?
System Info
* Processor = Unknown CPU Typ
* Level 1 Cache = 64kB
* Level 2 Cache = 512kB
* Level 3 Cache = 0kB
* Physical Memory = 1023MB
* Paging File = 2462MB
Game Info
* Game Name = Max
* Game Filename = D:\DOS\MAX\MAX.BAT
* DosBox Version = 0.70
Plugin Info
* Dos32a = false
* KeyB = false
* CSDPMI = false
* CSDPMI Swap File = false
DosBox Conf file
# DosBox 0.70 Configuration file #
# Generated by ErikGG's D.O.G. DosBox FrontEnd #
[sdl]
fullscreen=false
fulldouble=false
fullresolution=640x480
windowresolution=640x480
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=normal,lower
mapperfile=
usescancodes=true
[dosbox]
language=
machine=vga
captures=d:\dos\max\capture\
memsize=16
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=normal
cycles=auto
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
device=default
config=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=
[speaker]
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[bios]
joysticktype=2axis
timed=false
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=disabled
serial2=disabled
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=none
[ipx]
ipx=false
[autoexec]
mount y "d:\dos\"
Y:
cd/
cd max
call MAX.BAT
Reply 3 of 8, by tenangstroms
Wow! Someone else likes MAX!
M.A.X. is the whole reason I downloaded DOSBox.
I found that music and the cinematics audio was skippy when using the gravis ultrasound soundcard emulation.
The c:\max\setup.exe program automatically picks the gravis soundcard.
To fix it, I went into dosbox.conf and changed it so gus=false. This makes it so the only emulated soundcard that will be found is the soundblaster 16. After you make that change, restart DOSBox and run c:\max\setup.exe.
Run autodetect and it should pick the Sound Blaster 16 with IOport 220, IRQ 7, and DMA 5.
When I was playing, these settings worked much better than the gravis, no more skipping, but there were a lot of popping noises.
So I ran setup.exe again and chose the original Sound Blaster with IOport 220, IRQ 7, and DMA 1. Note that I left sbtype=sb16 in dosbox.conf. The left and right sound channels both sound like they are just the center channel with this setting, but I heard less popping noises with this selection. Since MAX doesn't really have much need for stereo sound, I like this selection best.
My recommendation is to try the above and pick which soundcard selection works best for you. Hope it solves your problem.
When you get it working shoot me a message sometime (I think this board allows private messages). I only know one other person who plays MAX, and we need some more opponents! The DOSBox IPX emulation worked great for us.
Reply 5 of 8, by tenangstroms
This problem is probably over my head, but I'll give it a shot. I have been able to run MAX with IPX.
Here is what I do:
-I have MAX installed to the virtual C:\MAX (really C:\DOS\CDrive\MAX)
-I have ipx=true in my config file
-I start DOSBox, at the prompt I type "IPXNET STARTSERVER"
-After this my buddy types "IPXNET CONNECT xxx.xxx.xxx.xxx:213"
-At this time I can see my buddy is connected in the status window
-I double check the connection by typing "IPXNET PING" and I should see my buddy's ping (we normally get ~20-25ms)
-I type "CD MAX"
-Finally at the "C:\MAX" prompt I type "MAX and run the game. From there you go into host or join network game
Can you walk me through what you do if it is any different? Or if it is the same, at what point do you crash? What do you mean by your "system crashes" is your entire PC going down? or just DOSBox? Or is DOSBox still running and MAX running into one of its infinite loops?
