First post, by moxie
I'm having trouble with a freeze up in Tangled Tales when the game requests the original floppy.
The game runs smoothly and saves successfully to the hard disk. However, when you tell your party to rest, it says "Please insert the original Adventure 1 disk in drive A or B ." This is followed by a message that says "Please use original disk only." It is here that the game locks up.
I'm running the D-fend front end and have mounted a C: drive for the hard disk. I created an A: drive that I set to floppy and is directed to the Tangled Tales game file directory. All of the game files rest in that directory and none are an image type.
Any ideas on how to get the game to recognize the game disk or just bypass completely?
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
did you mount or use imgmount for the floppy ?
You should try imgmount
Water flows down the stream
