First post, by LordYoh
I couldn't exactly find what I was looking for under the search, so here's to hoping you guys can help me out.
I found a full install image of the game in torrent land which i promptly downloaded. I installed the game, but was however, unable to configure the sound, and thus installed it with no sound settings set.
I downloaded DOSBOX and patched both it and SWARS with a couple of files I found on http://syndicate.lubie.org/swars/html/swars_run_newpc.php
Running SWars on its own in WinXP is not possible as the game runs like its on Crack.
Running it in DOSBOX works well, because the frame rate is much more manageable and for that matter human.
My questions are, how can I effectively set up the sound so I can hear the great music again?
And, how do I resize the DOSBOX window to play the in a large window?
I appreciate the time you take to read my post, and hopefully help me =D
