First post, by freddyd
I have an Avocet old compiler , DOS version, which does not run on dos windows in WinXP, but runs fine with DOSbox 0,70 on winXP, but very slow : a compilation which takes les than 1 second in a W98 window takes 25s on the same computer (I have dual boot) in dosbox with windows XP. The computer is AMD 64 3GHz, 1G ram. I have allready disabled sound etc ... , here are some parameters (file dosbox.conf attached) :
I would appreciate any idea to improve speed !
machine=vga
memsize=256
frameskip=20
aspect=false
cycles=max
cycleup=500
cycledown=20
nosound=true
mpu401=none
sbtype=none
gus=false
pcspeaker=false
joysticktype=none
xms=true
ems=true
umb=true
keyboardlayout=none
    dosbox.conf
    7.02 KiB
    153 downloads
Reply 2 of 6, by DosFreak
and that memsize=256 does nothing. Maximum value is 64.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 3 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Yep, core=dynamic, maybe set cycles to a high value, instead of max.
Offtopic: Also I see some big no nos in your conf
MOUNT C C:\ SET PATH=C:\AVC\BIN;c:\avc\avs;c:\WINDOWS\SYSTEM;c:\WINDOWS\SYSTEM32 SET TEMP=C:\WINDOWS\TEMP SET TMP=C:\WINDOWS\TEM […]
MOUNT C C:\
SET TMP=C:\WINDOWS\TEMP
SET AVOCET=C:\AVC\
mode con codepage prepare=((850) C:\WINDOWS\COMMAND\ega.cpi)
mode con codepage select=850
keyb br,,C:\WINDOWS\COMMAND\keyboard.sys
You really shouldn't mount the root of C:\ and you certainly should not add your Windows directories in the path. You are asking for trouble,
All this keyboard stuff is really not necessary (does it even work?), just set keyboardlayout to the one you need
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 6, by DosFreak
DOS games don't use any more.
Reply 5 of 6, by freddyd
Dominus wrote:
Yep, core=dynamic, maybe set cycles to a high value, instead of max. […]
MOUNT C C:\
SET AVOCET=C:\AVC\
    DOSBOX.txt
    940 Bytes
    262 downloads
    Thank you guys for the suggestions, which I apply ..... but did'nt work : still ~15-20seg to perform a compilation.
