First post, by DMurray
Hi everybody.
Did anyone manage to get 3DSR4 running correctly on any DosBox version?
At 25000 or 27000 cycles, it works normally, from what I've tested, only (hehe, only) the rendering is bad. If I either render a material (Mat Editor) or a view (3D Editor), DosBox crashes and outputs this error:
"Exit to error: Pagefault didn't correct page"
When the bar reaches the end, the program crashes and goes back to the terminal. I tried with no conf file (default options) and with my regular conf, which only adjusts memory size and cycles.
System here is:
Athlon64 3000+, Asus A8V, 1GB RAM, Geforce 6800, Kubuntu 6.01.1 64bit. I didn't try other versions of DosBox because 0.65 is the one currently in Ubuntu repositories.
Just for your info, running 3DSR4 on DOSEMU doesn't cause this unexpected crash, but there are some memory allocation bugs and the render seems to be working only in grayscale.
If you need some more info, let me know. I'd like to read your experiences.
TIA
Reply 2 of 13, by DMurray
WD, thanks for your heads up. I will try the memory tweaks and see if they work. I'm afraid it worked for you without the tweaks, so the chances are slim for me, but we never know.
I will also try the 0.70 version.
When I have something new, either good or bad news, I will post.
Cheers.
Reply 3 of 13, by wd
Rank DOSBox Author
DOSBox Author
3dsr4 uses the pharlap extender, which is always a bit picky.
See if it works any better if you create an empty directory,
mount that as c: (like mount c c:\oldstuff\cdrive) and then
install 3dsr4 onto c.
Reply 4 of 13, by DMurray
Hi, everybody.
No luck yet, not even messing with the xms, ems and umb settings.
WD, by saying "install 3dsr4 onto c", do you really mean it? What if I don't have the installer anymore? I just have the thing in a dir, where it used to run, and point DosBox to this dir. What do you say?
Thanks a lot.
PS: running 0.70 on Windows XP x64 also crashes after a render.
Reply 6 of 13, by MiniMax
Rank Moderator
Moderator
DMurray wrote:
Hi, everybody. No luck yet, not even messing with the xms, ems and umb settings. WD, by saying "install 3dsr4 onto c", do you re […]
Hi, everybody.
Thanks a lot.
What where the file/folder paths for the application before you tried to run it from DOSBox? And what are they now, seen from inside DOSBox?
_________________
Reply 7 of 13, by wd
Rank DOSBox Author
DOSBox Author
Think having it in c:\3ds4 (or 3dsr4) should be best as it's the default installation directory.
That is if you copied it into c:\oldstuff\3ds4 then use "mount c c:\oldstuff"
Try reconfiguring it, using "3ds vibcfg" to bring up that setup dialog.
Reply 8 of 13, by DMurray
"unless you have some dodgy cracked version". DH4RM4, you pretty much nailed it :shy: . I never thought it could be the cause of the problem, hopefully you are wrong, my friend. =) But it doesn't crash in DOSEMU, like I mentioned before, but the render is only grayscale and DosBox has much better stability in this particular app. 3DS sometimes "hangs" for a few seconds during the use, it happened when I changed from a Pentium 100 to a K6 233, and DOSEMU "emulates" the hangs, but DosBox doesn't, which is good.
The path on which it currently runs is, indeed, 3DS4. The partitions are arranged this way: C: is NTFS, WinXP partition, D: is FAT32, which I use as a swap space between Linux and Windows, plus the Linux partitions.
3DS4 is in D:, so I mount as "mount C D:\" or "mount C /media/hda5" if in Linux, and then navigate to 3DS4 to execute the 3ds.exe (C:, cd 3ds4).
As for VIBCFG, I used a Tseng ET6000 2D PCI card with the ET4000 driver, worked fine in its time. Now that I use a Geforce 6800 AGP, I seem to have no choice other than using the VESA driver, 1024x768x256 colors is the best I can use, since 1280x1024x256 colors doesn't pass the test (I can't see the pattern). I have no idea on what other driver could work.
If you guys need some more info, please let me know. Anyway, I will post the error message which is output when 3DS crashes in DosBox for Windows. When I get back from work, I do it.
Thanks in advance.
Reply 9 of 13, by MiniMax
Rank Moderator
Moderator
3DS4 is in D:, so I mount as "mount C D:" or "mount C /media/hda5" if in Linux, and then navigate to 3DS4 to execute the 3ds.exe (C:, cd 3ds4).
I don't care shit about how it is *now* - I want to know how it *was* before you tried to run it in DOSBox.
_________________
Reply 10 of 13, by DMurray
It was always 3DS4. The thing was backed um in a CD and now copied to the hard disk the way it was.
"And what are they now, seen from inside DOSBox?", I thought you wanted to know how it looked "now".
Cheers.
Reply 12 of 13, by dh4rm4
I'd recommend that you try YHKWONG's CVS Build (check the CVS thread here on the forums) as that has an ET4000 built in.
Reply 13 of 13, by MiniMax
Rank Moderator
Moderator
I doubt that. And you still haven't answered my question. But that is your choice. If you don't want to answer me, I won't bother try to help you.
_________________
