First post, by lillesvamp
As per this thread
Infrequent hangs on OS X Intel?
I'm having trouble compiling the cvs source of DOSBox on OS X. When activating the dynamic core, it crashes on an illegal instruction. The same thing happens when I compile my own 0.70 from source, but not with the official binary.
I also get warnings like
ranlib: file: libcpu.a(core_dynrec.o) has no symbols
ranlib: file: libdos.a(cdrom_ioctl_win32.o) has no symbols
ranlib: file: libserial.a(directserial_win32.o) has no symbols
I'm using i686-apple-darwin8-gcc-4.0.1, sdl 1.2.9-1002 and sdl.sound 1.0.1-1001.
Does anybody have any idea what I'm doing wrong?
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
those errors are fine actually. as those files are empty on mac os x in 32 bit mode.
The only special thing about your configuration is the gcc4 thing. I don't know what the other mac os x users are using.
edit they appear to use the same version.
could you attach the config.log after you have build/configured dosbox ?
Water flows down the stream
Reply 2 of 6, by lillesvamp
Okay, here are the config.logs from the two versions I have tried to compile.
Reply 3 of 6, by Psykechan
I'm using the exact same version of gcc straight from the xcode packages: i686-apple-darwin8-gcc-4.0.1
I believe that version 4 or higher is required for compiling on intel Macs.
Reply 4 of 6, by lillesvamp
And your build works with core=dynamic? Just to clarify, compilation works just fine, it's only when I try to run the dynamic core that I get "Illegal instruction".
Well, let's compare notes then.
I've installed all external libraries with Fink, and I've used no compiler flags or anything, just plain ./autogen.sh, ./configure, make.
Could it be some multicore thing? What's your CPU?
Of course I would be very grateful for a copy of that binary of yours. My email begins with ignalina and ends with mac.com.
Thanks in advance.
Reply 5 of 6, by Psykechan
I checked my "DOSbox Preferences" file and it was set to core=auto, which should automatically switch to dynamic mode. I did manually change it to core=dynamic and successfully ran DOSbox with no errors, but I didn't really test it long.
Early 2006 iMac (Core Duo 1.83GHz) and the build was made using SDL libraries installed with MacPorts and with no compiler flags.
My earlier build is downloadable from this thread thanks to Qbix.
DOSBox Intel Mac fix build from CVS
Please note that the SDL libraries are not part of this build, i.e. they are dynamic, not static, which has absolutely nothing to do with DOSbox's dynamic core option. I'm pointing this out for two reasons.
1. There is the remote possibility that it could be your libraries causing the error. I think this is unlikely but you should keep that in mind.
2. Can someone help me compile DOSbox with static libraries so I can distribute the resulting .app file to other systems so they don't have to install libraries from MacPorts or Fink?
Let me know if you still want me to send you my build or any other info.
Reply 6 of 6, by lillesvamp
Thanks, I got it to work after making symlinks to all the relevant libraries in /opt/local/lib/.
I still would like to know what's wrong with my own build though.
