First post, by zor_oro
hi i am new here i just got the copies of my friends crusader no remorse & no regret games and am having problem running them
my system spec are
mother board-A7N266VM
processor- AMD athalon xp 1800+
memory- 256mb DDR
o.s & HDD- win XP sp2 & 40 gb hDD
sound -creative SBlive gold 4.1 edition
games -crusader-no remorse & no regret
dosbox- ver 0.65 CVS & v 0.70
problem i am facing is that i have installed both the games correctly as per the guides & looking at the problems faced by other players i have had no installing the process i followed is
i have copied the cds to a folder (2 diff folders for 2 games)
(cruse-for no regret & cru2- for no remorse)
1.) i started by for no regret:-
mount d d:\cruse\
d:\cruse\
d:install
(it installed the games i can hear the sound also during installation)
then when it completes it says i can play the game typing REGRET
but on typing it it always says me cant find no regret cd
i mounted the d: as cd rom also but can seem to get a go with the game
do suggest me what to do?
2.) then i started for no remorse
mount d d:\cru2\
d:\cru2\
d:install
(it also installs the game with full instalation selected & an hear the sound during installation)
then it completes the installation & it says that i can play the game typing CRUSADER
but typing it also gives an error msg
FILE HALTED .due to error in FAST FLEX LINE 38
same as here i have mounted the d: as cd rom & tried once more but no go!!
plz can any one help me out with the problems
plz can u give me ur valuable solutions
thank you!!!!
Reply 1 of 5, by DosFreak
Soo....let me get this straight...
You copied your Crusader CD to your hard drive.
You mount the folder where you copied the crusader to your hard drive as your "d" drive.
You then run the Install program and install Crusader to your "D" drive.
You don't see anything wrong with this?
All you need to do is stick the Crusader CD in your hard drive.
Not which CD drive letter your crusader CD is in Windows.
Create a GAMES folder in your "C:\" drive.
Execute DosBox.
Type in "mount c c:\games" to mount your "C:\Games" as your emulated "C:\" drive.
Type in "mount d d:\ -t cdrom -ioctl"
Where "D:" is whatever your host CDROM drive letter is.
Switch to your CD drive by typing "D:"
Install Crusader to your "C:" drive.
Start the game.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 5, by njaydg
Crusader games (both No Remorse and No Regret) are among the most tricky to get working in Dosbox... All you need to do is mount a C:\ drive (where you'll install Crusader to), then mount the D:\ drive (with your real cd/dvd drive, where the Crusader CD is, or mount a CD image), make a full install from D:\ (Crusader CD or image) to C:\ ( like C:\CRUSADER ).
Configure sound to SB16 (base address 220, irq 7, dma 5) and leave it at 22050 mixrate. Copy the whole FLICS dir from CD to C:\CRUSADER and edit CRUSADER.CFG (inside C:\CRUSADER) and change these two entries like this:
cdletter=c
flicpath=.\flics
This way you can play CRUSADER (both of them!) on you HD with no need for CD or image...! 😎
I'll try to start my "nearly 100 favorite DOS games successfully played in Dosbox list" here in the forums in JULY, when I return from my vacation trip.
In the meantime, feel free to give some feedback.
Reply 3 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Configure sound to SB16 (base address 220, irq 5, dma 5)
Unless you changed Dosbox' settings, IRQ has to be 7 not 5!!!
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 5, by njaydg
You are right, Dominus!
Just a slight distraction... As in fact the majority of DOS games under DOSBox run damn fine with the default setting SB16 0x220 irq 7 dma 1 hdma 5 .
Oh, and as a sidenote, most errors with Crusader games I've seen in this forum are due to poor instalations, mismounting drives and corrupted RIP versions of the game (even the graphic problem when you see Crusader's HUD with black background plus the main character's trails as he moves on the screen, it's NOT a DOSBox output configuration problem - also happened to me when I tested a RIP version).
Reply 5 of 5, by Dominus
DOSBox Moderator
I fully agree with you!
