First post, by xain
here is my problem with dosbox 0.70 (running on vista ultimate)
using the default Dosbox configuration, i run it then i type :
mount c d:dosbox
(where dos stuff are stored)
c:
cd cmd
keyb fr (freedos keyb command) with keyboard.sys
=> now, when i try try to use mount command or imgmount command (mounting an iso image): it doesn't work (the syntax is correct and no error messages are displayed). if i simply type mount : nothing displayed too.
if i don't use keyb command, no problem.
any idea ?
thanks and sorry for my bad English.
    45.57 KiB
    DosBox_Snap
Reply 2 of 4, by MiniMax
Rank Moderator
Moderator
Is there anything special in that cmd directory?
_________________
Reply 3 of 4, by eL_PuSHeR
Rank Moderator
Moderator
I agree with WD. For me (Spanish keyboard), internal dosbox keyb works just fine. I just added a "keyb sp" line to the end of the [autoexec] section in dosbox.conf
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
