First post, by tommyswf
After i enter play on C:\ then it frozen and come up this line of error
Exit to error: CPU:GRP5:Illegal Call 7
Im using DOSBox 0.70
which game ? and on which os. and what did you enter inside dosbox.
Water flows down the stream
Hello
My game is chinese , so i think you wont know about it
if i run the game with "Play.exe/SKing.exe" straight away on the cmd it will came up a error line with
[ERROR]: Executing internal subfile...
Do you have any idea about this ?
Ok, here if i run the "Play.exe/SKing.exe" with DOSbox it come up
*SKing.exe also is the game start .exe
