About Magic Carpet 1...
First post, by LightNingzZ
I can play the game but the speed goes too fast or too slow when I change it....How can I set it to the required speed? can't really play like that 🙁
Thanks for helpers :]
Reply 1 of 24, by leileilol
then don't change the speed adjustment key at all then
Reply 2 of 24, by LightNingzZ
And play with unplayable speed?
Really smart 🙁
Reply 3 of 24, by DosFreak
Don't change it? According to you it runs fine if you don't change it. That's what leileilol was commenting on.
Make your games work offline
Reply 4 of 24, by LightNingzZ
I ment the speed is NOT OK atm...
I wanted to change it to normal playable speed...
Now can someone really help ? 🙁
Reply 5 of 24, by eL_PuSHeR
Try typing CYCLES MAX 80% at the dosbox Z:\> prompt before running the game.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 6 of 24, by LightNingzZ
Tried..it's still slow as hell 🙁
If I type less % or more it will change the speed?
tried some didn't work 😦
Reply 8 of 24, by LightNingzZ
Aw..the worst.
I got intel processor 256 ram 1.5 gigahz..
geforce 2 mx
Reply 9 of 24, by wd
Rank DOSBox Author
DOSBox Author
What dosbox version? What OS?
Reply 10 of 24, by LightNingzZ
I'm using dosbox 0.65 I saw some replies saying it;s better than 0.7..
XP SP2
Reply 11 of 24, by wd
Rank DOSBox Author
DOSBox Author
Well try 0.70 and see yourself. Maybe you'll like the speed improvement though.
Reply 12 of 24, by LightNingzZ
Hmm..now I use dosbox 0.7 and magic carpet works with playable speed..
but no sound is set and it will crash if i'll touch the details
what build should i use?
And 1 more thing..can I invert mouse? :0
Reply 13 of 24, by wd
Rank DOSBox Author
DOSBox Author
Reinstall the game within dosbox and be sure to select the correct
sound card with the right settings (irq=7, dma=1).
dosbox does not provide a way to invert the mouse axes, maybe the game does.
Reply 14 of 24, by eL_PuSHeR
[Moved]
Intel i7 5960X
8 GB DDR4 (2100)
Reply 15 of 24, by LightNingzZ
Where i select that details you wrote?
And what you mean by "install"? i just mounted c:\ and entered c:\CARPET
CARPET.EXE that's all 😦
Reply 16 of 24, by wd
Rank DOSBox Author
DOSBox Author
Um i doubt the game came preinstalled, check your original disks.
Reply 17 of 24, by dvwjr
Damn.
One of the things that makes the VOGONS website much nicer than all the other wanna-BEs out there is that fact that the message area is not overrun with garish and large picture sigs. The avatars should be enough.
Could the next version of the VOGONS web-site eliminate images such as those emplaced by LightNingzZ? 😒
Just my 2 cents,
dvwjr
Reply 19 of 24, by dh4rm4
haha..
