Originally posted by Mutaito I tried the "repair" option and now the installation gives me no errors. The problem now is that when I try to make "run with VDMS" right-clicking on a file, an error apears: "Instantiation - COM error" saying something about the emulation module 'VDMServicesProvider' and then it asks if I want to continue.
Hrrmm...this always smells wrong...
1st, did you read the text from Vlad's link on a possible solution?
His link broke on me a few times so here's the short version:
There is a problem with your Windows Installer and/or system
in general.
Install VDMSound in the C:\Program Files\VDMSound (def […]
in general.
Install VDMSound in the C:\Program Files\VDMSound (default)
directory. Ignore all errors. Then open the attached zip
archive here and double-click on the .reg file inside. Ignore
the warning (press OK). VDMSound should now work.
I would go ahead and do a shutdown-and-restart after that to be on the safe side.
If that still doesn't do it, I would uninstall VDMSound (and any/all add-ons/updates) then start over in what I call "Let's pretend this is Windows 3.1" mode. Play it safe and change the install directory to some location with a nice 8+3 identification like:
C:\Utils\Audio\VDMSound
After it finishes, shutdown-and-restart then try a simple DOS program like Ms.Pac-Em from here before you even try any updates or add-ons.
