First post, by DosFreak
- l33t++
List all games with problems in this thread. Hopefully it will turn out that people are not using the right options or imaging their floppies correctly. (Probably true in most cases)
Must use at least DosBox 0.70 as a starting point but you can mention earlier releases if the game's copy protection worked before.
