Aces of the Pacific
First post, by Grayson301
i have aces up and running but what command in dosbox do i use to go full screen it runs small windowed, i have tryed telling aces to run in full screen but i think the problem is in the command from dosbox
help
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
The keycombo mentioned in the readme doesn't work for you??
Reply 2 of 4, by Grayson301
i figured out how to get full screen mode by editing the config file... set full screen mode to( true ).. but the sounds not like i remembered it its beeps and whisles not the sound of gun fire when i fire my guns and not the clink and chip of pelting when i'm hit but small pops and clicks from the speakers this one i have not got fixed its like using an OLD adlib card
Reply 3 of 4, by wd
Rank DOSBox Author
DOSBox Author
Maybe somewhen you'll actually read the readme, dunno.
How did you configure sound?
Reply 4 of 4, by eL_PuSHeR
[Moved]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
