as has been proven by other Crusader: No Re... requests for help, it helps to do this:
- delete everything from your hard drive that got installed in previous trials to get the game running.
- make a folder named Games in c:\
- put one of the game CD-Roms into the CD-Rom drive
-start Dosbox
- type the following and press enter at the end of the line
mount c c:\games
mount d (enter here your CD-Rom drive letter) -t cdrom
d:
install (or is it setup?)
Then install No Regret to c:\regret and after this No Remorse to c:\remorse.
To play you mount again c:\games as c and your cd-rom as d, pop in the right CD, change to the right folder (remorse or regret) and play.
Please follow these steps and if it doesn't work, report back at what step it doesn't work. Because both games work with Dosbox and in the past it always bboiled down to user errors when the games didn't work.
