First post, by james00794
I just recently found my old King's Quest 6 CD and decided that I would try and play it. I have installed it through DOSBox, and have mounted DOSBox to the folder c:\DOS\SIERRA. I'm pretty sure that I am doing this correctly. There is only one executable file in the folder, so I am using it to try and start the program. Whenever I try to run the file, I get a message which says "This program requires Microsoft Windows".
I would greatly appreciate it if someone could help me out.
Thanks. 😀
