First post, by Rickenbacker
So far I've noticed that DOSbox (using latest version, 0.70) doesn't recognize when I press the Up and Right arrow simultaneously, or the Down and Left arrow. Up and Left are fine, as are down and right, and this is quite annoying because I'm trying to play Tyrian2000. I've also tested out Crusader, and the input problem seems to be the same, so I've ruled out Tyrian2000 being to blame.
Any suggestions?
Reply 1 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Question is is your keyboard capable of passing multiple keys in all cases. PS/2 keyboards should. USB not necessarily.
1+1=10
Reply 2 of 6, by Rickenbacker
Yes, outside of DOSbox there are no problems with input.
Reply 3 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
I don't have that problem with Tyrian 2000. What platform are you on?
(Btw the mouse is a much better input device for Tyrian 😉 )
1+1=10
Reply 4 of 6, by Rickenbacker
Windows XP SP2. I just might consider going to mouse, if that's the case.
Though I'd like to see if this can be resolved for future reference.
Reply 5 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
With space and two arrow keys?
I doubt it'll help but you can try changing usescancodes in dosbox.conf.
1+1=10
Reply 6 of 6, by wd
Rank DOSBox Author
DOSBox Author
Maybe try SDL_VIDEODRIVER=windib as well.
