First post, by coltrane
Is there any way to execute a .exe file directly from dosbox.conf ? I tried to run brucelee.exe by putting it into the autoexec.bat section but it doesn't work.
Thanks.
Thanks.
Put the required mounting, drive changing, cd xyz stuff and finally
the execution of the .exe into the [autoexec]-section of dosbox.conf
