Command and Conquer
First post, by EvoCaliber
C&C complains that there is insufficient disk space which is not true. Any help?
BWT, i am trying to run the original DOS version from '95.
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
did you mount a c drive (non cdrom) ?
and did you take a look at the freesize parameter for mount ? (see readme)
Water flows down the stream
Reply 2 of 4, by EvoCaliber
hmm not working,
mount cd drive with mount d e:\ -t cdrom
and c&c
mount x d:\games\c&c -freesize 12 ( as it only wants 8 )
btw, its not working in the sense that it wont start if i restart dosbox, from a fresh install it runs fine.
Reply 4 of 4, by MiniMax
Rank Moderator
Moderator
Why do you mount the directory as X ??
_________________
