DOSBox crashes
First post, by Smiling Spectre
After new update of DOSBox I try to start one-two games, just to check work. Games itself works good, but on the Alt+Enter system goes mad. I start in window mode, and full screen mode after that not always refresh whole screen. And when I try to Alt+Enter from full screen to window, colors turns to "EGA feelings" (it seems, remains only 8-16 colors), then DOSBox crashes.
It is definitely not common problem - because I have older versions of DOSBox, and it never did this before - now it do. Even DOSBox 0.65 and ykhwong builds. It is not OS - the Windows XP SP2 (rus) is on my system already several years. So it must be my new hardware or drivers.
I have P4 with dual core, DX 9.0c, Internal video Intel 82915G/GV/910GL Express chipset with latest drivers and SoundMAX as audio.
What can be the source of problem?
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
now it do
What is "now"?
Reply 2 of 5, by leileilol
Guess your video card doesn't like surface output. Try something else (ddraw, overlay, opengl)
long live PCem
Debian's fucked
Reply 4 of 5, by Smiling Spectre
wd, I mean "now every version of DOSBox crashes when I press Alt+Enter in the full screen", where "now" is "after changing motherboard".
Qbix, it was not joystick. 😀 (I tested it - no change).
leileilol, yes! You are right! output=ddraw do the trick! Thank you! 😀
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
Upgrade/downgrade your graphics card drivers then,
and test the (new) memory for errors.
