F22 Lightning II
First post, by wolferlll
I have troubles to install this programm. Can you help me with this, i tried some changes on the config(cycles to max, and mem to 64), but still the same problem. The Problem is, that i get the error message: insufficient extende memory - can´t found the file setup.exe.(but the file is install.exe)
I tried it with dosbox 0.7 and dosbox 0.71
My system is an AcerSystem Genuine Intel CPU t2050 @1,60 Ghz
1.60ghz, 0,99GB Ram
graphics: Motibel Intel 945GM/PM/GMS/940GML and Intel(R) 945GT Expres Processor.
I tried also to make an image and mount this, but still the same problem. And i tried to copy the files on harddisk - sampe problem.
Thanks for you help.
Reply 1 of 11, by wd
Rank DOSBox Author
DOSBox Author
Play with the xms= and ems= settings in dosbox.conf, if they don't
help load "loadfix" before running the installer.
Reply 3 of 11, by leileilol
MobyGames is wrong. It's a DOS game. Totally.
They're confused by that PIF shortcut with an icon. Guess that identifies it as 'windows game'
Reply 4 of 11, by wolferlll
Its a dosgame, (and i tried it under windows).
the xms and ems settings? I have here in the config a "true". What other parameters can i try? ( I look in the readme, but )
And i tried loadfix, and still the same problem.
Reply 5 of 11, by wd
Rank DOSBox Author
DOSBox Author
=false
Reply 6 of 11, by wolferlll
still no luck, tried some varations.
Reply 7 of 11, by wd
Rank DOSBox Author
DOSBox Author
No idea.
Maybe post a screenshot, that message about setup.exe missing
seems a bit odd. Any batch files around (install.bat)?
Reply 8 of 11, by wolferlll
d:
Joystick [Dir]
Nova [Dir]
Vesa [Dir]
install.exe
readme.text
Nova [Dir]
install.bin
resource.res
and i started the install.exe file, and then i have the error message and now i´m in the Nova [Dir].
Reply 9 of 11, by dvwjr
I have access to the Novalogic 1996 game F-22 Lightning II (which is a DOS game) that will install under Dosbox v0.70. However, Dosbox game play at even 640x480 with a Pentium IV 640 (3.2GHz) is quite slow. Since I had originally installed this for a young nephew I found a better performance solution...
I purchased on eBay the Novalogic 1997 game "F-22 Raptor", which was basically a re-release of the Novalogic 1996 DOS F-22 Lightning II using Win95 era DirectX version 5 and a software renderer. This is one case where dumping the DOS version for the Windows version makes sense.
The only advantage of the DOS F-22 Lightning II version is that screen resolution can go to 1024x768, where as the Windows 95 based F-22 Raptor is locked at 640x480, unless the multiplayer F-22 IBS upgrade is applied.
As an aside, the official Air Force name for the F-22 did turn out to be "Raptor" instead of "Lightning II". However, the new F-35 did pick up the "Lightning II" designation.
Hope this helps,
dvwjr
Reply 10 of 11, by wd
Rank DOSBox Author
DOSBox Author
The error message is quite misleading, the problem is as simple as
that the installer needs a drive c: mounted.....
Reply 11 of 11, by emodel
I have it and it works nicely.
Its not too slow, considering what is displayed 😀
(its even almost smooth here)
Latest dosbox cvs on windows xp sp3
