Descent
First post, by joeb1234
Can't get the sound to work. I'm using dfend as a front end. Sound is Realtek AC 97. Can anyone help? 😢
Reply 1 of 4, by leileilol
Instead of whatever it's autodetecting (GUS) just try the Sound Blaster 16 instead, and enter through the default choices
Reply 2 of 4, by joeb1234
Thanks for the suggestion, but it does'nt seem to work. Strange, all the old microprose games (Subwar 2050, PAW and B17) work with the same audio settings as Descent
Reply 3 of 4, by Neville
For that particular game there is a Windows port, it's called DX-Rebirth, and can be found at http://www.dxx-rebirth.de/
If you can't make it work within DOSBox, then it's an option.
Reply 4 of 4, by wd
Rank DOSBox Author
DOSBox Author
Descent works just fine in dosbox, sb16 addr=220 irq=7 dma=1.
