First post, by Interceptor
is this supposed to run? anyone got it running okay?
i've tried different core, memory and sound settings and i just get
ILLEGAL INTERRUPT #00
eax = 0F424000 esi = 00000032 flags = 3202 ds = 0033
ebx = 00000007 edi = 00000000 eip = 000395FC es = 0033
ecx = 0004F750 ebp = DFFFED00 cs = 002B fs = 0000
edx = 00000000 esp = DFFFECF4 ss = 003B gs = 0000
it returns this immediately after running the executable within dosbox
not reallt sure if i can be much more help on this or not. i tested this with version 0.70. 0.71 just crashes when i start it, but i read this is a known bug being fixed.
host machine is Core 2 duo E6600, G965 chipset, 600GT gfx, Sigmatel HD audio.
for he most part dosbox works very well on this machine.
Reply 1 of 3, by Interceptor
okay, forget this, it works. but i'm leaving the original post here for reference. the problem was that the install.exe program will store the STARDUST.CFG file in a subdir called STARDUST wherever you specifiy it. so if you run "install c:\stardust" then you get the file in c:\stardust\stardust\stardust.cfg. which it doesnt like.
Reply 2 of 3, by Interceptor
ah crap and i cant edit messages either. i mean setup.exe not install.exe
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
You were fast with figuring that out 😀
Thanks for posting your solution to this problem!
