First post, by giocamoto
The game in the subject works perfect in dosbox v 0.71, the only thing I concern on; is that changing or raising the resolution in the setup menu doesn't affect the ingame resolution that will be always 640x480 etc. I tried also modifying directly the redneck.cfg but anything change. Anyone know a workaround or there isn't a solution?
Best Wishes. 😊
