First post, by Caine
hi guys & girls !
i have a problem with shadowcaster, i wanted to finally play this game after well 10 years i bought it?:)
ok everytime the intro or first cutscene begins it lasts only about 5 seconds and fails to load any further ! then a normal dos window appears and tells me something like "cd error 100 dev req: write protection error" this game is original from ea cd-rom classics.
i can continue the game after the mesage but i really want to see the cutscenes too.
thanks !
Reply 1 of 11, by MiniMax
Rank Moderator
Moderator
Operating system?
DOSBox version?
Drive mounting in DOSBox?
Command to start Shadowcaster?
It is not like kind of information is top-secret....
_________________
Reply 3 of 11, by DosFreak
Wow. Then your problem with the game must not be a secret either and should be easily fixable correct?
How about posting some detailed information?
Your OS and Service Pack Level
What version of DosBox you are using.
The EXACT mount commands you are using for your HD and CD.
It sounds to me like your running the game off the cdrom.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 4 of 11, by Caine
OS:
Windows XP Pro SP2
Intel Core 2 CPU 6600 @ 2.40 GHz
2.00 GB RAM
Dosbox Version:
0.71
mount:
the standard setting + at the end the automatic orders:
mount C f:\dosgames
C:
mount D "D:\" -t cdrom -ioctl
THX !!!!!
Reply 5 of 11, by MiniMax
Rank Moderator
Moderator
Hmm, looks perfectly okay to me.
Did you install the game from inside DOSBox? From the D: prompt in DOSBox?
_________________
Reply 11 of 11, by Og
The free version of ISOBuster can do that, although occasionally it doesn't detect the ISO mode correctly, and then you have to open the cue file and manually change "MODE2/2352" to "MODE1/2352" or vice versa.
