First post, by UncreativeNameMaker
When I run Chronomaster with DOXBox 0.71 it works fine until I try to go to a planet. Then it crashes. No error message. I've tried it on two diffrent computers (both XP), and had the exact same problem on both.
The only way I've found to get past this is to run Setup and disable the sound. I've experimented with a few diffrent sound settings without any luck. Any thoughts on how to run the game with sound would be appreciated.
Reply 1 of 1, by red_avatar
You're most likely using the ripped version which can be found on sites like Underdogs. I just tried my CD version and it works perfectly BUT before you arrive on a planet you get a movie clip with your ship taking you there. Maybe it tries to find a speech file?
If you want to get passed it, try disabling sound or music in the settings of the game itself (don't run setup) and see if it works. It would be easier.
