First post, by ErikGG
Whenever I start DOSBox and open the mounted diskdrive before Fallout starts I get the following error, see the screenshot.
This happens in DOSBox 0.65, 0.70 and 0.71.
After pressing cancel "Annuleren" then fallout starts without any problem.
Erik.
    30.9 KiB
Read the new FAQ.doc
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
opening a mounted drive ? Is that actually possible in windows ?
In linux the tray won't open.
Water flows down the stream
Reply 5 of 7, by ErikGG
I'm using the folowing function to lock the cdrom drive while extracting the audio from a game disk in my experiental Audio extractor.
procedure NTStyleTrayLock(Device: THandle; Lock: Boolean);
var
Dummy : Cardinal;
PMR : TPREVENT_MEDIA_REMOVAL;
begin
if Lock then
PMR.PreventMediaRemoval := 1
else
PMR.PreventMediaRemoval := 0;
DeviceIoControl(Device, IOCTL_STORAGE_MEDIA_REMOVAL, @PMR,
sizeof(PMR), nil, 0, Dummy, nil);
end;
Erik.
Reply 6 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
not sure if that is a good idea. Under linux it is quite hard to change cdroms when in dosbox, because of this locking.
