First post, by argan
So I´m trying to run Archimedean Dynasty again. I have nolfb and VDMS is installed...according to the nolfb website I have to use it with the dosprompt, so is there any way for me to run e.g. ad.exe with VDMS from the dos prompt?
Thanks. 😀
Reply 1 of 5, by eL_PuSHeR
Edit the .VLP shortcut and insert the line calling NOLFB (with full path if needed) in the advanced options properties sheet.
DOS Environment -> Autoexec.bat
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 5, by eL_PuSHeR
It's supposed to be in the game's folder. If not, maybe you need to check some option in VDMSound to create it. Look at the image.
    39.57 KiB
Intel i7 5960X
8 GB DDR4 (2100)
