Vinyl Goddess From Mars
First post, by Shadow
I have VDMSound and it runs ok but it is laggish.
furthermore the music sometimes speeds up or down. i want to know how to fix the speed up/down problem. thanks 😀
Reply 1 of 3, by Snover
search: SPEEDSET.
Yes, it’s my fault.
Reply 2 of 3, by maYO
I suggest, you try DOSBOX
http://dosbox.sourceforge.net
I got that game running. Only problem were some slowdowns now and then. But I guess, if your pc is powerful enough then this shouldn't be a problem.
Don't know if the sound works properly, cause I had it running on my notebook with the sound turned off 😉.
DOSBoxGui - multi platform DOSBox frontend
check my weblog (german only)
Reply 3 of 3, by Nicht Sehr Gut
Originally posted by maYO I suggest, you try DOSBOX
maYO is right, the way Vinyl plays audio induces the lag when run from the NTVDM. If you were to shut off all the audio it would be smooth. So, use DosBox (AFTER having read the README that comes with it) and adjust cycles as needed for your PC. It ran smooth on a 1.7GHz Celeron with DosBox.
