First post, by Xian97
http://nwn2forums.bioware.com/forums/viewtopi … 89581&forum=121
Quoted from Bioware's forum
Hello Everyone, […]
Hello Everyone,
There is currently a patch available on the Autopatcher. DO NOT INSTALL THIS PATCH!
If you do, it will overwrite your CD Key(s) and cause you much havoc.
Edit
If this patch has already been installed, you will need to manually open the file "nwncdkey.ini" and replace the CD key(s) with the original keys you entered at the time of installing the game. The file can be found in the NWN2 install folder.
If you have a backup of nwn2cdkey.ini from after you installed MotB, you can instead just restore the file from your backup.
Reply 2 of 3, by eL_PuSHeR
Yeah, you may need this hotfix too: Missing dialog hotfix
At least, they are fast releasing fixes. 😁
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 3, by leileilol
DosFreak wrote:
Isn't Obsidian great? Keeping PC gaming interesting by releasing buggy games....what would we do without them.....
that, and publishers bribing the reviewers to highly rate the bugfests
long live PCem
