DOSbox Help.
First post, by Axmand
Hi,
Im new in this but here i go.
Im trying to play C&C95 i follow the steps of various guides to run the game using DOSbox but no result. 😢 The same thing happen when im try to run others games. 🙁
I mount Drivers and files still no result, always when the guides ask put the install/setup commands or when they ask to mount a new directory.
I hope you can tell when im wrong.
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
I am sorry Axmand, but my magic crystal ball don't work tonight. It will not show me what you tried, so I don't know what you did wrong.
_________________
Reply 2 of 5, by bugs_bugger
Are you sure that C&C95 is a Dos program?
Reply 3 of 5, by Axmand
No but the DOSbox can run the game, because if you install the game for Win2000/XP you need de DOSbox.
Also i already seen some poeple do it.
@MiniMax give some time you give the exact details... are you agreed?.
Reply 4 of 5, by wd
Rank DOSBox Author
DOSBox Author
No, the other way round, you tell what exactly you did, and what the
respective error messages are, what you tried then etc.
Reply 5 of 5, by leileilol
If this is the freebie ISO release from the official Command & Conquer site, then no, it doesn't work in DOSbox because this one's the Windows 95 version.
long live PCem
Debian's fucked
