First post, by qavorq
Hi folk - Im sure there is already a post answering this but I cant find it. What I want to know is how do I install a dos game under linux to use with dosbox?
Im using a dual boot pc linux/vista so I could install under vista if I knew how to access it in linux. Yes I know I could run it in dosbox under vista (and Ive successfully installed and run LBA2 there) but I want to do it in linux as Im learning how to use that at the moment. Thanks in advance for any help.
