First post, by StickByDos
I've connected a 5.1 speaker kit to a SB Audigy Platinum under win98se
When I choose Surround speaker from multimedia property in control panel:
- Speaker test from CT AudioHQ doesn't route sound to correct speakers
Only fron speakers are use
Rear speakers repeat front speakers with lower intensity
During rear testing intensity is decreased
Center speaker is mute, its test is played throught front speaker
- Speaker test from WinDVD6 works correctly
When I choose stereo speakers:
- Speaker test from CT AudioHQ works correctly
- Speaker test from WinDVD6 only works with 2 speakers
Type win to loose the power of your computer !
