First post, by Nils
Hello
I've got MAC OS X and when starting DOSbox from Finder it doesn't seem to make use of my "dosbox.conf" configuration file.
I figured out that when starting DOSbox from Terminal the dosbox.conf file has to be placed in the current working directory, but in Finder it doesn't seem to work.
Where should i put my "dosbox.conf" file under OS X so that DOSbox makes use of it when it is started with Finder?
Is there a way to write a batch file in order to start dosbox with custom parameters just from finder by doubleclick?
greetings from germany
Nils
