Extreme Assault
First post, by Glidos
Administrator: The files that were in this first post of the thread are no longer needed since v1.18 of Glidos, and have been removed.
This is a zip file containing an updated version of the file Glide2x.ovl. Use this as a replacement for the original with Glidos v1.17 to make Extreme Assault work.
You should also add this text to the bottom of your Glidos.ini file:
[snip]
Reply 2 of 6, by DosFreak
Dangit Nicht, Didn't want to be presumptous and modify his post....now I look like a dumbass. 😁
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 3 of 6, by Nicht Sehr Gut
DosFreak wrote:
Extreme Assault. 😉
How wude... use the the "Thread options" next time...You big meanie.
BTW, here's the 1.20 patch that allows you to use the retail version of "Extreme Assault" with GliDOS.
    xa_e120.exe
    492.2 KiB
    1712 downloads
