First post, by emynii
I understand about not starting new threads of previously answered questions, but I do need some help.
I've been perusing the forums for almost an hour now and tried several of the suggestions listed, none which work. I may be doing them incorrectly, as I'm not very advanced with this stuff.
I have gotten many Dos games to work on my computer, but it seems that Gizmos and Gadgets is determined not to run. Every time I try to open the game, it tells me that "A VGA Graphics Adapter Card is required to run Gizmos & Gadgets!"
I'm not sure what this means, and I'm not sure how to fix it. I run off of Windows XP and have a nividia graphics card. Is there anyone who can spell this out for non-programmers? Thanks so much.
Reply 1 of 9, by wd
Rank DOSBox Author
DOSBox Author
What dosbox version are you using?
Reply 3 of 9, by MiniMax
Rank Moderator
Moderator
It would help us a million times if you could copy/paste ALL the commands you use in DOSBox.
_________________
Reply 4 of 9, by emynii
I start with:
Z:\>mount c C:\bestoldgames
Z:\>c:
C:\>cd gizmo
C:\GIZMO>dir
C:\GIZMO>ssg.exe
and it gives me the error
A VGA graphics adaptor card is required to run Gizmos & Gadgets!
Reply 5 of 9, by MiniMax
Rank Moderator
Moderator
Hmmm. Looks okay to me. If you give the command machine in DOSBox, what does it say? Should say vga.
_________________
Reply 6 of 9, by emynii
It says "vga" but still gives me the error.
Reply 7 of 9, by ripsaw8080
Rank DOSBox Author
DOSBox Author
From the DOSBox game compatibility list (always a good place to check):
http://dosbox.sourceforge.net/comp_list.php?showID=3387
It seems the game is supported, but there is the suggestion of using command line parameters, most notably the -gv parameter, which I would guess relates to graphics.
Reply 8 of 9, by emynii
Thank you so much, using the command:
C:\GIZMO\>ssg -gv -sb
worked perfectly! thank you so much for your help.
Reply 9 of 9, by wd
Rank DOSBox Author
DOSBox Author
Interesting, their vga check would fail on several bioses, including the
original ibm vga. Maybe it can be changed though so it works with dosbox.
