First post, by Kreshna Aryaguna Nurzaman
- l33t
See, this is about the Soyo SY-845PE ISA in my possession. I plan to build an all in one retro PC on it.
I don't really care about DOS games that runs on 320x200 resolution, since DOSBOX can always handle them gracefully. My goal is to run the following games:
(1) Hi-res, unacellerated DOS 3D games running on SVGA like Privateer 2: The Darkening/, System Shock 1 (yes, the CD version has 1024x768 resolution), Duke Nukem 3D, Hi-Octane, Sandwarriors, and Top Gun: Fire At Will.
(2) Early GLide games like EF2000 V2.0, Jetfighter III, Jetfighter III: Full Burn, Flying Corps Gold, Red Baron II, Jane's F-15, Mechwarrior II and Interstate 76.
(3) Quite a wide range of Direct3D games, from something as old as Hellbender to quite demanding game like Jane's USAF and Crimson Skies.
Alas, the slowest processor being supported by Soyo SY-845PE ISA is Celeron 1.7GHz, while the fastest being Pentium 4 3.06 GHz.
Is a Celeron 1.7GHz too fast for the purpose I describe above? For example, Interstate 76; anyone ever experienced problem with the game on fast system?
Or maybe I should actually use Pentium 4 anyway, because Celeron 1.7GHz is too slow for the likes of Jane's USAF and Crimson Skies? Nonetheless, I believe I still need slowdown utils anyway; what would you suggest? Is Moslo the best slowdown util for DOS games? And what is the best slowdown util for Windows games?
Kreshna Aryaguna Nurzaman.
